Alert Panel with template variables
I am testing new alerting system in Grafana 8.1.2 and setup my alerting rule as below.
Which works great for alerting but would also like to display alert list on one of my dashboards. Unfortunately, the alert list panel is showing all instances, not just the ones firing.
2021-09-23_21-35-57
I can add the threshold to the query to make the dashboard look nicer, but then obviously I lose the ability to use the mean reduce function so I get a lot of false positives when there is short spike in CPU usage.
Is there anyway to have the alert list panel play nicer with template variables?
I did find an open bug that describes my issue exactly. Must have missed it when first looking.
