Grafana 10 -
I want to add a template variable to a Dashboard where users will be able to select from a list of dynamic values.
The values should come from the alerts’ labels with he same name as the template variable.
For example, the template variable app should be populated with all the values ever assigned to the alert label app across all alerts.
Template variables and queries -
What happened?
I cannot find a way to query this information (list of all values attributed to an alert label across all alerts). -
Some way to query this data. -
N/A -
N/A -
N/A
