Good Morning,
Trying to setup a filter for a panel. Have a variable that the user can select one or more values from. It is suggested that it is possible to use the Filter by Value transformation to accomplish this, but I do not seem to be able to get it to work.
The datasource is Loki Fluent Bit, the loki version is 2.9.3 and grafana is version 10.2.3
This post from the community suggests that it may be possible
How can I try Datagrid visualization?
We have enabled transformationsVariableSupport
Any suggestions on how to get this to work or indeed if it is not possible, would greatly appreciate advice
Kind regards
Marc
