I am using csv data source and Loki data source. I am joining the data from Loki and csv at UI level. I know I can pass $variable_value into Loki query but how can I pass variable value to a csv column to filter table according to input given in variable?
I am using Grafana open source version.
I tried this one but its not working. I think its matching $variable as string. Its not replacing $variable with actual value. Do I need to enable that somewhere?
Found a way to solve this. Go to grafana.ini file and set the below param
[feature_toggles]
transformationsVariableSupport = true
[feature_toggles]
enable = transformationsVariableSupport
