Hi all, I am trying to use the transform in panel but it seems not working when I use two different fields. when I tried to use Binery operations on same field , grafana shows the field but as soon as I select other field, the output disappear.
I used STAT and Table both but same result. Grafana is working perfect when I am doing binery operations on 1 field (means add 1000 or subtract or divide or multiply) but as I select another field instead of number, the output disappear.
example info:
I am trying to do binary operations (add or divide) on this month_cost and customer_count but as soon as I Grafana is not displaying it. If I use same field then Grafana displays the result. I am currently using Grafana 7.2.0.
