Field aggreagation in table panel
  • Grafana 8.0.0-ubuntu
  • want to do field aggregation based on columns?
column_aggreagation
Now, I want to the aggregation for these three columns and show below these data points. Suppose I choose total then
it should come in next row total(column1)=4694, total(column2)=0.210,total(column3)=100
  • I am getting the option to do the aggregation on a row basis in transformation but I am not getting the option for doing column-wise
  • I suppose to get all the data points then below that aggregation of above data points.
Hi @gautamravikant6,
You can use the reduce transformation to reduce a column of values to a single value. That is what I did here with a very similar table:
https://play.grafana.org/d/Z3p4r4i7z/table-aggregate-transform?orgId=1
