I created a backup of my config file using
sudo mv /etc/grafana/grafana.ini grafana.ini.default
Copied that default file back to the default location
sudo cp grafana.ini.default /etc/grafana/grafana.ini
When restarting the grafana server I am receiving the following errors.
lvl=crit msg=“Failed to parse /etc/grafana/grafana.ini, open /etc/grafana/grafana.ini: p
ermission denied”
I suspect the account running the grafana server/service does not have access, but I cannot find what the required permissions are for the grafana.ini file.
The current permissions are:
-rw-r----- 1 root root 15105 Jan 16 18:03 /etc/grafana/grafana.ini
What are the chmod commands needed to reset these file permissions for the grafana group?
