Failed to get plugins repo from grafana.com after upgrade
    I was using Grafana version 8.1.8 and I upgraded to version 8.5.14.
    After upgrading, I see this error, which I’m trying to resolve:
logger=plugins.update.checker t=2023-02-02T13:55:34.19+0000
lvl=dbug msg="Failed to get plugins repo from grafana.com"
error="Get \"[https://grafana.com/api/plugins/versioncheck?slugIn=sfdc-filter]
(https://grafana.com/api/plugins/versioncheck?slugIn=someplugins
&grafanaVersion=8.5.14)
http: server gave HTTP response to HTTPS client
Any insights would be appreciated!
hi @ngalagali :wave:
can you give us more context about the plugins you have installed?
you can list your plugins and their version via the following command in grafana-cli
grafana-cli plugins ls
There are a bunch of plugins but I think somewhere in the code the HTTP response wasn’t expected. But I didn’t need to get plugin updates so I was able to stop this check by setting check_for_plugin_updates to false in the analytics section of the custom.ini file.
