Extract fields using regex
Hello!
I have a log message and trying to extract the “trace_id” using regex but unable to.
{“log”:“2024-10-29T14:24:40.877Z\u0009INFO\u0009frontend/best_eta.go:103\u0009Dispatch successful\u0009{"service": "frontend", "trace_id": "4c49bb2657a30ce58265e6ed014f150d", "span_id": "8c9a87f20fcd5434", "driver": "T727878C", "eta": "2m0s"}\n”,“stream”:“stderr”,“time”:“2024-10-29T14:24:40.877565888Z”}
matcherRegex: "trace_id":"(\w+)"
Can I get some help ??
You can simply use the json filter if your logs are in json format (which looks like it is).
I’m trying to extract it from the loki derived field. So how can I use a json filter ?
Attached the snippet for reference.
Got it working!!
Had to escape the backslash in regex.
\“trace_id\”:\s\“(\w+)\”
