Hi Team,
I am having my log setup from grafana telegraf and loki. and all the logs are coming in the grafana panel but I am not able to extract the information from that log.
I am using [[inputs.tail]] parser to get the log and pattern is grok with greedy data. as my logs are not in the same format.
Sharing some sample log here:
jsonstring="{“channel”:“crm_process_booking_log”,“log_type”:“DEBUG”,“index_name”:“crm_process_booking_log”,“index_type”:“crm_process_booking_log”,“error_type”:0,“message”:{“data”:{“STEP”:“Booking Successful”,“action”:“Booking Created”,“message”:“Booking (123) placed successfully.”,“amzn_trace_id”:“Root=1-61a76286-4e9cd6ffb47157340d”},“calling_trace”:{“file”:"/var/www/newcrm/application/abc.php",“line”:998,“function”:“addProcessBookingLog”,“class”:“Enterprise_logger”}},“amzn_trace_id”:“Root=1-61a76286-4e9cd6ffb47157340d”,“nginx_request_id”:“de0bfcae0ad79e38195ebaf6”,“timestamp”:“2021-12-01 17:24:46”}"
jsonstring="{“channel”:“crm_process_booking_log”,“log_type”:“DEBUG”,“index_name”:“crm_process_booking_log”,“index_type”:“crm_process_booking_log”,“error_type”:0,“message”:{“data”:{“STEP”:“booking_updated”,“slot_data”:{“samplecollector_id”:0,“isavailable”:0,“booking_id”:“123”,“user_id”:false},“amzn_trace_id”:“Root=1-61a76286-4157340d”},“calling_trace”:{“file”:"/var/www/newcrm/application/abc.php",“line”:1652,“function”:“addProcessBookingLog”,“class”:“Enterprise_logger”}},“amzn_trace_id”:“Root=1-61a76286-4157340d”,“nginx_request_id”:“de0bf80a3595ebaf6”,“timestamp”:“2021-12-01 17:24:46”}"
and in most of the cases I want my log to be extracted from booking_id i.e. 123
this Booking_id can be come inside message object as string or as a key value like “booking_id”
so i want to apply some generic pattern that will bring all instances for a perticular booking_id or a perticular word.
Any help would be appreciated.
Thanks,
Shweta
