Hey everyone hope you all are doing well I am in trouble can someone please help me :
we’re fetching logs from promtail into loki.
we’ve the following log entry from which we need to pull out status code, requestdatetime and requestresponsetime.
however, as the log line is huge we are unable to create a regex out of it for labeling purposes - so, we need an assistance/guidance w.r.t. how to parse the log to pull out needful data
Sample; below example we can work out - but as our line is huge - how can we create similar regex for it
127.0.0.1 - - [01/Jan/2023:21:33:40 +0100] “GET /grafana_local/api/search?dashboardUIDs=alP6m1c4k&limit=30 HTTP/1.1” 200 525 “http://localhost/grafana_local/?orgId=1” “Mozilla/5.0 (X11; Linux x86_64; rv:108.0) Gecko/20100101 Firefox/108.0”
{job=“apache”} | pattern
<ip> - - [<dttm>] “<method> <resource> <protocol>” <status> <object_size> “<referer>” “<user_agent>“ -
<ip> - - [<_>] “<_> <_> <_>” <_> <_> “<_>” “<_>“
2023-05-29T12:46:57.437Z 0123abcd-xz12-9kjh INFO { type: ‘LOGS RESPONSE’, information: ‘{“channel”:“myapplication”,“principalId”:“abcd142s”,“statusCode”:200,“headers”:{“OperationName”:“GetDetails”,“MessageId”:“0123abcd-xz12-9kjh”,“RequestDateTime”:“2023-05-29T20:46:57.424”,“ResponseDateTime”:“2023-05-29T20:46:57.437”,“X-Frame-Options”:“deny”,“X-XSS-Protection”:“1; mode=block”,“X-Content-Type-Options”:“nosniff”,“Strict-Transport-Security”:“max-age=31536000 always; includeSubDomains”},“body”:“{\“result\”:[{\“number\”:\“123456\”,\“alias\”:\“alpha\”,\“age\”:\“10\”,\“channel\”:[\“myapplication\”],\“isLinked\”:false,\“position\”:0,\“Detail\”:\”\“,\“quickAction\”:[\”|SecondaryDefault|1\“,\”|SecondaryDefault|2\“,\”|SecondaryDefault|3\“,\”|SecondaryDefault|4\“,\”|SecondaryDefault|5\“,\”|SecondaryDefault|6\“,\”|SecondaryDefault|7\“]}]}”}’ }
