9.5.7 -
Resampling data on a query with multiple metric (mysql) -
Using a resample expression in Query -
What happened?
All the metrics are labeled with the same query name -
A unique name by resampled metric, so that they can be accessed individually
Hello, I have the same issue…
grafana v9. 1.6
When I change one metric name in the Overrides panel, all metrics names change !
This issue occurs when I add the latest query , wich content the same topic as the first one:
from(bucket: "BddNew")
|> filter(fn: (r) => r["_measurement"] == "mqtt_consumer")
|> filter(fn: (r) => r["_field"] == "value")
|> filter(fn: (r) => r["topic"] == "/Exterieur/Maison/Prod")
|> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
|> yield(name: "OldMesure")
|> filter(fn: (r) => r["topic"] == "/Solaire/ECU/408000047303/out" or r["topic"] == "/Solaire/ECU/408000158298/out" or r["topic"] == "/Solaire/ECU/408000047182/out")
|> filter(fn: (r) => r["_field"] == "p0" or r["_field"] == "p1")
|> group(columns: ["_time", "_field"], mode: "by")
|> group()
|> aggregateWindow(every :2m, fn : sum)
|> yield(name: "OldPanneaux")
|> filter(fn: (r) => r["topic"] == "/Solaire/ECU/1" or r["topic"] == "/Solaire/ECU/2" or r["topic"] == "/Solaire/ECU/3" or r["topic"] == "/Solaire/ECU/4" or r["topic"] == "/Solaire/ECU/5" or r["topic"] == "/Solaire/ECU/6" )
|> filter(fn: (r) => r["_field"] == "pwr_0" or r["_field"] == "pwr_1" )
|> group(columns: ["pwr_0", "pwr1"], mode: "by")
|> group()
|> aggregateWindow(every : 5m, fn : sum)
|> yield(name: "NewPanneaux")
Amp = from(bucket: "BddNew")
Volt = from(bucket: "BddNew")
|> filter(fn: (r) => r["topic"] == "/BorneVE/Tension")
join1 = join(tables: {Amp: Amp, Volt: Volt}, on: ["_time"])
|> map(fn: (r) => ({ r with _value: r._value_Amp * r._value_Volt }))
|> drop(columns: ["_value_Amp", "_value_Volt"])
|> map(fn: (r) => ({r with _value: r._value / 241.001 }))
|> yield(name: "NewMesure")
It’s a bug or I’ve done something wrong?
