An Expression using metrics from a Query with multiple metrics
v11.3.2 on Linux
I want to use a single Query on an elasticsearch data source to provide multiple metrics and then use those metrics in an Expression.
In my Expression, I tried using the identifier that I would use to reference a given metric in a Transformation: ${Sum foo.bar.baz}.
I also tried using a Transformation to reference a metric and then referencing the Transformation via its alias, e.g. ${abs-sum-foobarbaz}, in my Expression, but it appears as if I cannot reference a Transformation from an Expression.
  • What happened?
Both attempts yield an error message: "Query data error".
I expected to be able to perform mathematical operations on my various metrics within the Expression, for example 1 + ${Sum foo.bar.baz} would produce a number 5 in my Gauge visualization.
I can’t copy-paste because this is for work, and I’m not to disclose any info about data schemas. But here’s a screenshot with some areas covered.
Here’s the error from the Grafana UI, produced during the Transformation attempt (with some sections collapsed for the reason given above):
I have no instructions.
