We are trying to use a panel from grafana in an HTML page by using the following code snippet:
However, when the html page is rendered in the browser, the panel is showing as an editable panel and not as a read-only panel.
Are there any settings in grafana.ini to enforce this or anything additional to be added as part of iframe src tag above?
Thanks in advance,
Ahir
Hi! Could you please post the snippet in a code block? Can you verify that it is editable for any user - it might be that you are still logged in. Could you maybe post a screenshot too?
Thanks for your response to the query. Appreciate much.
My code snippet in HTML that I am trying to open is as follows:
CM Cell
If I logged into grafana in the same browser, will it show as editable?
ahirbudhnya:
<html>
<head>
<title> CM Cell </title>
</head>
<body>
<iframe src="http://grafana.staged-by-discourse.com/d-solo/OhcrZJ9Zk/covratetotal?panelId=2&orgId=1&refresh=30s&from=1585358872545&to=1585380472545" width="950" height="800" frameborder="0"></iframe>
</body>
</html>
I don’t know, is it possible for you to provide screenshots to show what you mean with editable? You could always try logging out in the same browser and see if it changes, but I feel like it shouldn’t.
I have attached the screenshot with this response.
Thanks
Hi!
Did you get the embed code by clicking the panel dropdown->Share->Embed?
