Hi all,
I’ve just migrated from Grafana OSS 11.4 to 11.5.
I’ve noticed a new “Export” button:
Even a viewer can easily download the dashboard definition, which I’d like to avoid.
In 11.4 the export functionality is accessible through the “Share” button. It’s not as visible, but still allows the viewer to download the JSON model.
Is there a way to disable this functionality for a viewer role?
Thank you!
