Customize viewer dashboard
I’m using grafana 9.3.6, and want to expose some dashboards to our customer via Viewer role user. But I don’t want to reveal details of grafana except panels in dashboard. So I want to customize dashboard to remove sidemenu, left toolbar and kiosk button like below when viewer is visiting:
Is there any thoughts to implement this?
Hi @maplefengwang,
Thanks for opening this post.
Well, this is not possible to hide unless (maybe a custom feature is available in the Grafana Enterprise version).
However, there is an alternative way to do this by using the Public Dashboard feature.
You can check its documentation as to how to use it and also this blog post (see those screenshots as they hide all of that what you also want).
I hope this helps.
