How to make a specific panel not visible to a user(Editor/Viewer) in a grafana dashboard having many panels
    v10.0.3
    trying to make a specific panel not visible to a user
    not sure how to achieve
  • What happened?
If by a panel you mean the dashboard, there is a permissions section in the dashboard settings:
Delete the “Viewer” and “Editor” permissions, and add the team/user that you want to give access to.
@clevernessisamyth , I am having a dashboard as below screenshot with 4 panels.
I am trying to disable/hide ‘logins’ panel to Viewers. Is there a way to achieve this?
No it is not possible.
You should create a new dashboard without that panel…
As a workaround you can convert that panel into a library panel:
Create library panel
And configure necessary permissions for the folder containing this library panel:
Viewers won’t see the content of this library panel used at a dashboard, but result would not be very nice anyway. Viewers would see “Panel plugin not found: Unable to load library panel” message:
So more efficient approach would be, as mentioned above, to create a new dashboard without that panel
