Hey there,
I’m doing some health check requests in the setup stage since the api might not have been started entirely when the test starts running. Can I exclude those requests somehow from metric collection? I use http.get to make the requests.
thanks in advance
Jannik
unfortunately there’s no way of excluding metrics per request, but if you tag them then you could exclude metrics with those tags when processing the results in whatever backend or output you used, e.g. by using an InfluxQL or jq filter.
Though in fairness, this might be a good feature to support: pass an exclude
flag to the request params or similar.
Hope this helps,
Ivan
Hey,
I figured as much. It would indeed be a great feature to support
I’ll try tagging.
Thanks,
Jannik
