Follow but ignore redirects?
Hey
Bit of a specific one. Is there a way to essentially have successful redirects “ignored” in the report metrics?
I’ve recently created some tests that can sometimes have redirects depending on the version of the software being tested but we then noticed that the number of requests in the metrics essentially doubled as it’s counting both the redirect and successful request.
Is it possible to have redirects ignored then in metrics such as http_reqs. Also thinking about it I guess redirects will also be counting towards RPS as well (which we also use).
Guess another way of putting it is can we have a way to treat a redirect as part of the same request instead of more?
Cheers,
gy
Unfortunately, that’s currently not possible in a straightforward way. Add explicit tracking and ignoring of metrics and sub-metrics · Issue #1321 · grafana/k6 · GitHub is a proposal that attempts to tackle this issue, but I can’t give any guarantees when it, or something like it, would be implemented.
That said, depending on your specific use case, there are some workarounds. You might not know that k6 tags the HTTP metric values it measures, so you can differentiate between metrics from HTTP requests with a 200 status for their response, and those with 30x (i.e. redirects). The easiest way to do that is to use an external output and explore the raw data k6 produces.
You can also differentiate between requests in the end-of-test summary by setting thresholds on sub-metrics, based on the response status tag. Here’s a simple example:
import http from "k6/http";
import { sleep } from "k6";
export let options = {
    vus: 20,
    duration: "30s",
    thresholds: {
        "http_req_duration{status:302}": ["p(99)<300"], // Measure only redirects
        "http_req_duration{status:200}": ["p(99)<2500"], // Measure only non-redirects
export default function () {
    // This will redirect to a page that will take 2 seconds to return
    http.get("https://httpbin.test.loadimpact.com/redirect-to?url=https%3A%2F%2Fhttpbin.test.loadimpact.com%2Fdelay%2F2&status_code=302");
    sleep(Math.random() + 1); // Random sleep between 1s and 2s
this will result in an end-of-test summary somewhat like this:
    data_received..............: 231 kB 7.7 kB/s
    data_sent..................: 33 kB  1.1 kB/s
    http_req_blocked...........: avg=69.35ms  min=2.73µs   med=3.35µs   max=1.07s    p(90)=5.55µs   p(95)=1.07s
    http_req_connecting........: avg=21.26ms  min=0s       med=0s       max=329.37ms p(90)=0s       p(95)=328.2ms
    http_req_duration..........: avg=1.12s    min=135.11ms med=251.2ms  max=2.37s    p(90)=2.18s    p(95)=2.19s
    ✓ { status:200 }...........: avg=2.16s    min=2.13s    med=2.15s    max=2.37s    p(90)=2.19s    p(95)=2.2s
    ✗ { status:302 }...........: avg=165.44ms min=135.11ms med=149.9ms  max=360.92ms p(90)=206.07ms p(95)=212.72ms
    http_req_receiving.........: avg=171.23µs min=29.97µs  med=95.88µs  max=3.19ms   p(90)=163.07µs p(95)=190.5µs
    http_req_sending...........: avg=89.55µs  min=33.33µs  med=77.28µs  max=1.68ms   p(90)=127.29µs p(95)=140.28µs
    http_req_tls_handshaking...: avg=39.87ms  min=0s       med=0s       max=617.06ms p(90)=0s       p(95)=615.41ms
    http_req_waiting...........: avg=1.12s    min=134.96ms med=250.99ms max=2.37s    p(90)=2.18s    p(95)=2.19s
    http_reqs..................: 309    10.299796/s
    iteration_duration.........: avg=3.97s    min=3.31s    med=3.89s    max=5.43s    p(90)=4.6s     p(95)=5.14s
    iterations.................: 140    4.666574/s
    vus........................: 20     min=20 max=20
    vus_max....................: 20     min=20 max=20
Another potential workaround option would be to use custom metrics and timings values in the HTTP Response object. For a request chain, the timings should contain only the metrics for the last request.
Or, you can set the maxRedirects option to 0, so that k6 doesn’t follow HTTP redirects automatically, and build a simple wrapper around the k6/http module that handles redirects manually, and uses custom metrics again to track precisely what interests you.
In summary, k6 is pretty flexible :sweat_smile: And as seen in #1321, we’d like to make it more so, but there are plenty of workaround available even now.
Thanks for this. I was already sort of exploring some of those possible solutions yeah but just wanted to check. It is flexible indeed!
For the tags potential solution am I right in assuming you can specify a range or (regex) in the thresholds? E.G. {status: 20[0-9]}? There’s a few success and redirect codes sadly.
No, unfortunately, only exact values are permitted at the moment. This is the proposal to improve it: Allow more flexible sub-metics and better UX in thresholds · Issue #1313 · grafana/k6 · GitHub
Ah ok cool, no problem!
