Hello guys,I want to see the load(http_reqs) allocated on each API. How do I configure the K6 script?
Anyone can provide a demo?
Unfortunately you can’t delete the submetric right now, we have to implement Add explicit tracking and ignoring of metrics and sub-metrics · Issue #1321 · grafana/k6 · GitHub first ![]()
However, you can hide it by implementing a custom handleSummary() function that prints the end-of-test summary without it, see End of test
Good point about systemTags, I didn’t realize that by excluding expected_response from them you’d also hide the default sub-metric on it…
Just keep in mind that with your current setting of just ['scenario', 'status'], you are also telling k6 to not attach a lot of other useful system tags to your metric measurements. Which you might need, since I see you are using an InfluxDB output.
Anyway, to answer your question, I think this difference in iterations and http_reqs is not a bug in k6 or caused by the systemTags option you specified. It’s most likely a result of the gracefulStop: '0s' option you have in your scenarios. It will cause k6 to immediately abort any iterations that are still running at the end of the scenario, and k6 only counts full iterations in he iterations metric. So, I assume in one of these iterations at the end of the test, the HTTP request finished (and was counted in http_reqs), but the iteration was interrupted before it was also counted, and that’s why you see a difference.
Sorry, can’t help you a lot here, but I suggest editing the dashboard and filtering the metrics by the scenario tag, see InfluxDB data source | Grafana documentation
Anyway, thank you for my help @ned
