Is it possible to use selected built-in metrics
Hi All,
When running the test with a high number of virtual users over an extended period, The amount of metric captured in the json out file and influx db is too huge. Is there a way to eliminate some of the default metric captured ( like http_req_blocked, http_req_connecting, http_req_tls_handshaking, http_req_waiting) so that the data is more manageable.
Any other work around is also appreciated. Thanks in Advance
Regards
Bibin Mathews
Not currently, sorry :disappointed: Follow Add explicit tracking and ignoring of metrics and sub-metrics · Issue #1321 · grafana/k6 · GitHub, it’s one of our priorities, so hopefully it will be done in the next few k6 versions. The issue milestone is currently v0.33.0, but that’s somewhat aspirational :sweat_smile:
Thanks ned for the info, Will follow the ticket for further updates.
Regards
Bibin Mathews
