I am sending 4 requests to test a service: create, update, read, and delete. All requests work well in sequence. The summary that is generated at the end is for all the requests combined. The times for the 4 requests are averaged. Is there a way I can see the average response times for create requests separate from other 3 requests? I am finding it difficult to understand the output.
Am I doing it wrong? Should I be creating separate scripts for all 4 requests?
The summary aggregates all of the results it shows. The only current way to get around that, before we implement Add explicit tracking and ignoring of metrics and sub-metrics · Issue #1321 · grafana/k6 · GitHub, is to define a threshold on a sub-metric. I gave an example for that in Ignore http calls made in Setup or Teardown in results? - #2 by nedyalko, but if I understand your use case correctly, it would be something like this:
import http from 'k6/http'
export let options = {
vus: 5,
duration: "10s",
thresholds: {
// Some dummy thresholds that are always going to pass. You don't even
// need to have something here, I tried it and just this
// `'http_req_duration{scenario:default}': []` is enough to trick
// k6, but that's undefined behavior I can't promise we won't break
// in the future...
'http_req_duration{my_tag:create}': ['max>=0'],
'http_req_duration{my_tag:read}': ['max>=0'],
// You don't have to define custom tags, you can use any of the already defined
// system tags: https://k6.io/docs/using-k6/tags-and-groups#system-tags
'http_req_duration{method:POST}': ['max>=0'],
'http_req_duration{url:https://httpbin.test.k6.io/anything}': ['max>=0'],
'http_req_duration{status:200}': ['max>=0'],
export default function () {
http.post('https://httpbin.test.k6.io/delay/2', null, { tags: { my_tag: 'create' } });
http.get('https://httpbin.test.k6.io/delay/1', { tags: { my_tag: 'read' } });
http.post('https://httpbin.test.k6.io/anything', 'some body');
Alternatively, it might be better if you work with the raw metrics data directly by exporting it to JSON/CSV or sending it to InfluxDB or some other external service. You can see more details about that in Results output
