Error with docker build: unrecognized import path "go.buf.build/grpc/go/prometheus/prometheus"
I am trying to build a docker image but it failed with the following error:
k6 imports
go.k6.io/k6/cmd imports
github.com/grafana/xk6-output-prometheus-remote/pkg/remotewrite imports
go.buf.build/grpc/go/prometheus/prometheus: unrecognized import path “go.buf.build/grpc/go/prometheus/prometheus”: https fetch: Get “https://go.buf.build/grpc/go/prometheus/prometheus?go-get=1”: dial tcp: lookup go.buf.build on XXX.XXX.XX.X:XX: read udp XXX.XX.X.X:XXXXX->XXX.XXX.XX.X:XX: i/o timeout
[INFO] Cleaning up temporary folder: /tmp/buildenv_2023-08-04-XXXXXXXX
[FATAL] exit status 1
executor failed running [/bin/sh -c apk --no-cache add build-base git && go install go.k6.io/xk6/cmd/xk6@v0.9.2 && CGO_ENABLED=1 xk6 build --with GitHub - grafana/xk6-sql: Use SQL databases from k6 tests. --output /tmp/k6]: exit code: 1
Dockerfile is like this right now:
Hi @kkk1! We’ve had multiple reports of the issue. Please follow the topic at Unable to build custom k6 binary with extensions .
Hi @kkk1
A patch version v0.45.1 was released.
Thanks for reporting this.
Cheers!
