I can install k6 normally, but I cannot with xk6. I have tried it directly with go install and using docker. While the build finishes correctly in both scenarios, and both output this message:
2023-08-07 10:16:57 go: cannot match "all": go.mod file not found in current directory or any parent directory; see 'go help modules'
2023-08-07 10:16:57 2023/08/07 09:16:57 [ERROR] exec [go list -mod=readonly -m -f={{if .Replace}}{{.Path}} => {{.Replace}}{{end}} all]: exit status 1:
Shouldn’t the go.mod have been linked during build? I’m not familiar enough with go to understand what’s going on. Any help?
Hi @cyberglot
Welcome to the community forum
Let’s try to start troubleshooting generating the k6 binary with docker, can you share the output of the command:
docker run --rm -e GOOS=darwin -u "$(id -u):$(id -g)" -v "${PWD}:/xk6" \
grafana/xk6 build v0.43.1 \
--with github.com/mostafa/xk6-kafka@v0.17.0 \
--with github.com/grafana/xk6-output-influxdb@v0.3.0
from the docs?
If you are seeing this error:
k6 imports
go.k6.io/k6/cmd imports
github.com/grafana/xk6-output-prometheus-remote/pkg/remotewrite imports
go.buf.build/grpc/go/prometheus/prometheus: unrecognized import path "go.buf.build/grpc/go/prometheus/prometheus": https fetch: Get "https://go.buf.build/grpc/go/prometheus/prometheus?go-get=1": dial tcp: lookup go.buf.build on 192.168.65.7:53: no such host
It is due to an issue we identified last week. Try using the patched version of k6, v0.45.1:
grafana/xk6 build v0.45.1 \
Does that work? If it does, we can also look at the Golang install—probably a similar issue.
Cheers!
Hi @cyberglot
We’ve updated the documentation to reflect the changes in the commands to build extensions with docker: Build a k6 binary using Docker
Thanks for reporting this and let us know if you are still experiencing issues.
Cheers!
Thank you so much
, the new command works.
Hi @eyeveebee
Following xk6 docker page needs to be corrected to have v0.54.1 (version with these fixes), I was referring to this page, thankfully came to this post.
https://hub.docker.com/r/grafana/xk6
Thanks!
