I was trying to use an extension for protobuf support along with grpc extension that support streaming. When I launch the output binary using
./k6 run test.js
I get this error
[0000] GoError: unknown module: k6/experimental/grpc
I don’t get this error if I run the script using the system k6 binary but of course it fails to find the extension imports
Any idea how to solve this?
I’m using version 0.47
Hi @shoukryelfahl
Welcome to the community forum
Can you share a bit more context so we can help you figure this out?
- What extensions are you using?
- Can you share the command you use to build the k6 binary / the build steps?
- Can you share a sanitized version of
test.js
With this, we can reproduce it locally and help figure out what could be going on.
Thanks!
Thanks for the prompt response
I was using this extension to marshal protobuf to use with websockets and I used this command to build local k6 binary
xk6 build --with github.com/traveltime-dev/xk6-protobuf@latest --replace go.buf.build/grpc/go/prometheus/prometheus=buf.build/gen/go/prometheus/prometheus/protocolbuffers/go@latest --replace go.buf.build/grpc/go/gogo/protobuf=buf.build/gen/go/gogo/protobuf/protocolbuffers/go@latest
Note that I use --replace
to avoid a reported bug. The advice was to use this parameter which worked
Please find the content of test.js
and hello.proto
test.js
import { Client, Stream } from 'k6/experimental/grpc';
import { sleep } from 'k6';
const client = new Client();
client.load(['.'], 'hello.proto');
export default function (data) {
client.connect('grpcbin.test.k6.io:9001', {
plaintext: true
const stream = new Stream(client, 'hello/BidiHello', null);
stream.on('data', function (data) {
console.log(`Received message: ${data}`);
stream.on('end', function () {
client.close();
stream.on('error', function (e) {
console.log('Error: ' + JSON.stringify(e));
// send a message to the server
const message = { greeting: 'Bert' };
stream.write(message);
client.close();
sleep(1);
hello.proto
service HelloService {
rpc SayHello(HelloRequest) returns (HelloResponse);
rpc LotsOfReplies(HelloRequest) returns (stream HelloResponse);
rpc LotsOfGreetings(stream HelloRequest) returns (HelloResponse);
rpc BidiHello(stream HelloRequest) returns (stream HelloResponse);
message HelloRequest {
string greeting = 1;
message HelloResponse {
string reply = 1;
when using the ./k6 run test.js
it will throw the error but k6 run test.js
will work without a problem
@shoukryelfahl
Your xk6 build command produces a v0.43.1 k6 binary at my computer. Maybe because it is referenced here: https://github.com/traveltime-dev/xk6-protobuf/blob/master/go.mod#L7
was not supported in v0.43.1
Try to run (set explicit k6 version for xk6):
K6_VERSION="v0.47.0" xk6 build --with github.com/traveltime-dev/xk6-protobuf@latest --replace go.buf.build/grpc/go/prometheus/prometheus=buf.build/gen/go/prometheus/prometheus/protocolbuffers/go@latest --replace go.buf.build/grpc/go/gogo/protobuf=buf.build/gen/go/gogo/protobuf/protocolbuffers/go@latest
@bandorko It worked. Thank you
