grafana-agent:v0.40.1_A0 -
Trying to use Grafana agent as a collector to receive otel trace data and export it to elasticsearch for storage. -
I have configured the grafana agent data pipeline in an openshift cluster to receive the otel data, (the ports for otel grpc/http are opened) -
What happened?
When I send a sample trace I get the below error messages:
when using http in the url
Error: Exporting failed. Will retry the request after interval." component=otelcol.exporter.otlphttp.elastic error="failed to make an HTTP request: Post \"http://elasticsearch:9200/v1/traces\": EOF" interval=10.73036973s
when using https in the url
Error: Exporting failed. The error is not retryable. Dropping data." component=otelcol.exporter.otlphttp.elastic error="Permanent error: error exporting items, request to https://elasticsearch:9200/v1/traces responded with HTTP Status Code 406" dropped_items=1-removd colons around the url
the output on the cli for the sample trace:
curl -i https://grafana-agent-http-serverip.net/v1/logs -X POST -H "Content-Type: application/json" -d @span.json
HTTP/1.1 200 OK
content-type: application/json
date: Tue, 30 Apr 2024 18:32:27 GMT
content-length: 21
set-cookie: 6dbc74795e8e9b20ddcab6682a4dde93=0d5b23be19666d3e92c683ded09407f2; path=/; HttpOnly; Secure; SameSite=None
{"partialSuccess":{}}
We expected the trace data to be exported to the elastic backend -
apiVersion: v1
kind: ConfigMap
metadata:
data:
grafana-agent.river: |
otelcol.exporter.otlphttp "elastic" {
client {
endpoint = "https://elasticsearch:9200"
auth = otelcol.auth.basic.elastic.handler
tls{
ca_file = "/path/to/certs.pem"
otelcol.auth.basic "elastic" {
username = "userid"
password = "password"
otelcol.receiver.otlp "otel" {
grpc {
endpoint = "0.0.0.0:4317"
http {
endpoint = "0.0.0.0:4318"
output {
metrics = [otelcol.exporter.otlphttp.elastic.input]
logs = [otelcol.exporter.otlphttp.elastic.input]
traces = [otelcol.exporter.otlphttp.elastic.input]
logging {
level = "debug"
