I had a lot of trouble understanding how to get this going, so I thought I would post this here.
Go into the account-ui (not the stack-ui) and click “Open Telemetry”.
This shows you your instance-id and tells you the oltp endpoint
https://otlp-gateway-prod-us-east-0.grafana.net/otlp, which is wrong for
sending traces, but whatever.
On this page, you must also create they api-key (save it, no way to see it
later, I think?)
To construct the correct url for Otel SDK to send traces, you need to add
/v1/traces to the end of the oltp endpoint url:
https://otlp-gateway-prod-us-east-0.grafana.net/otlp/v1/traces.
Use /otlp/v1/metrics for directly sending metrics.
I only figured this out thanks to this topic:
From there, configure a new OtlpHttpSpanExporter and create a standard
Authorization header from the instance-id:api-key pair.
At this point, OTel started sending traces that I could see in the stack-ui
by navigating to / Explore / Traces.
String authPair = otelProps.grafanaCloudUser() + ":" +
otelProps.grafanaCloudPassword();
String basicAuthHeader = "Basic " +
Base64.getEncoder().encodeToString(authPair.getBytes());
var spanExporter = OtlpHttpSpanExporter.builder().
setEndpoint(grafana.url()).
addHeader("Authorization", basicAuthHeader).
build();
config.addSpanProcessor(BatchSpanProcessor.builder(spanExporter).
setMaxQueueSize(grafana.maxQueueSize()).
setMaxExportBatchSize(grafana.maxBatchSize()).
setScheduleDelay(grafana.scheduleDelay()).
setExporterTimeout(grafana.exportTimeout()).
build()
