I’m having a problem adding a new dashboard.
This problem started when I put the script behind a reverse proxy apache.
The grafana.ini settings are as below.
[server]
domain = graf.test.com
root_url = http://graf.test.com/dash
enable_gzip = true
The apache settings are as below
ProxyPreserveHost On
ProxyPass /dash http://grafana.staged-by-discourse.com
ProxyPassReverse /dash http://grafana.staged-by-discourse.com
I’m using https in apache to access grafana.
Can you see what url Grafana is trying to access in the Chrome dev tools?
Is that supposed to be https?
the URL and the following https://graf.test.com/dash/board/new?orgId=1&gettingstarted
The grafana is configured http, in reverse proxy apache is https
Yes but you configured the root_url to start with http - seems wrong to me.
already changed to
root_url = https://graf.test.com/dash
The error persists
Can you answer this then?
What information do you want?
Oh, think you’ve run into a bug with Grafana’s regex. The url is incorrect: https://xxx/dash/board/new should be https://xxx/dash/dashboard/new
The easy fix is to use something that is not dash or anything to do with dashboard for the proxy value.
OK it worked,
Thanks a lot for the help.
A big hug
