Hi team,
I am currently doing a calculation with the transform option, and the result should be 0.06, but it shows infinity.
Does anyone know what can happen?
The formula is:
(metric1 * 100) / metric2
metric1: 1.96
metric2: 3024
Hi team,
The formula is:
metric1: 1.96
metric2: 3024
Hi @richardmendoza83 ,
Can you share a screenshot of your transformations? I recreated your scenario on play.grafana.org using dummy data, and I received the correct calculation by using two Add field from calculation transformations:
