v8.3.4 / Ubuntu 22.04.1 -
Adding Prometheus as Data Source -
I installed Prometheus, Blackbox Exporter and exporter_exporter (reverse Proxy, so i can export all with one port) -
What happened?
When adding Prometheus as a data source, it shows an error message -
Data Source is working -
