Linux, Grafana v9.3.2 -
I have a public dashboard with a panel that displays an expression. The expression refers to prometheus queries that are hidden (I’m combining a couple of the query results in the expression). I only want to show the expression to show in the dashboard. -
I think the above explains it. Below is a screenshot.
What happened?
I see “no data” in the publically exported dashboard. Other panels work well.
I see the following errors in the logs
logger=publicdashboards.service t=2023-01-03T15:50:57.8934737Z level=error msg="Error querying datasources for public dashboard" error="expression request error: unable to find dependent node 'ipmi_compute'" datasources="[__expr__ prometheus]"
I would like to see the expression as it displays in the non-public dashboard.
Please tell me what else you need. -
Logs see above. -
No.
