9.5.2 -
Displaying the error message (query error) once providing the wrong PromQL as in previous version (8.5.21) -
Upgrade/Use version 9.5.2, go to explorer with an instance of Prometheus as the data source then set type with both, provide the wrong query such as* invalid{} -
What happened?
There is no error message appeared. -
It should appear Query Error as in previous version (8.5.21). -
No, since It’s not related to the configuration. -
The error not shown in version 9.5.2
If we provide the other query with an alias by the same name with appended with -Instant then the error will be attach to it.
But with the same test, the error is appeared in older version (8.5.21).
- Did you follow any online instructions? If so, what is the URL?
So far i’m not find the exact same error reported.
