On a Raspberry Pi 4, I followed the installation instructions on this website. When running sudo apt-get update I get an error message:
Err:6 https://packages.grafana.com/oss/deb stable/main armhf Packages
File has unexpected size (27478 != 27354). Mirror sync in progress? [IP: 2a04:4e42:1d::729 443]
Hashes of expected file:
- Filesize:27354 [weak]
- SHA512:fe677d1e4a50ca92b82cfe57adb6cc2749933ee325a4747d9d633bbe75c27d0d19ed1c11fc645e634b4f76d2c2d2154afbf5b3ac91507922b0b08b76c2ea01df
- SHA256:3eec60aaa41e3db7a652ac3d1fb36de89fe7c064ec31d477920f174ebc445f27
- SHA1:a9ed4fec0cacd952e62c42f62b3527518df0af84 [weak]
- MD5Sum:bfca550a082007e06a8d019be944195f [weak]
Release file created at: Thu, 15 Jul 2021 11:20:36 +0000
Reading package lists… Done
E: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/main/binary-armhf/Packages.bz2 File has unexpected size (27478 != 27354). Mirror sync in progress? [IP: 2a04:4e42:1d::729 443]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Of course, if I then run sudo apt-get install -y grafana, I get:
Building dependency tree
Reading state information… Done
Package grafana is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package ‘grafana’ has no installation candidate
Anything wrong your end ?
