Anyone having trouble accessing the grafana community dnf repo? I’m getting an error on dnf update.
My grafana.repo looks like this:
[grafana]
name=grafana
baseurl=https://packages.grafana.com/oss/rpm
repo_gpgcheck=1
enabled=1
gpgcheck=1
gpgkey=https://packages.grafana.com/gpg.key
sslverify=1
sslcacert=/etc/pki/tls/certs/ca-bundle.crt
Hi @laurielounge
sounds very likely related to this ongoing issue:
opened 03:46PM - 04 Jun 21 UTC
area/backend
priority/important-soon
type/bug
type/build-packaging
Get:6 https://packages.grafana.com/oss/deb stable/main amd64 Packages [22.2… kB]
Err:6 https://packages.grafana.com/oss/deb stable/main amd64 Packages
File has unexpected size (22262 != 22216). Mirror sync in progress? [IP: 2a04:4e42:4c::729 443]
Hashes of expected file:
- Filesize:22216 [weak]
- SHA512:f24db43b3572f6c5c556939cd349e2ded94defb17eb7ca1afcf22de7c9df54145839ff17ef86c8fee2ff72c8fa5beedbec7a49d2d7f72063101949e5bae24615
- SHA256:6ead907c843edeffa74b5e94b388981c180c4501d8b594fcd56be1cc62437f4a
- SHA1:5a7fcbd5e05eaac245babb25b531d6980cea936b [weak]
- MD5Sum:610876d8f36eca70808fbcf3f485a9fc [weak]
Release file created at: Tue, 01 Jun 2021 12:10:01 +0000
Hit:7 https://deb.torproject.org/torproject.org buster InRelease
Reading package lists... Done
E: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/main/binary-amd64/Packages.bz2 File has unexpected size (22262 != 22216). Mirror sync in progress? [IP: 2a04:4e42:4c::729 443]
E: Some index files failed to download. They have been ignored, or old ones used instead.
I forced IPv4 and got this as well.
