Error in installing v10.3.1
Hi I tried installing the lastest version v10.3.1 Grafana Enterprise on windows 64b OS. I got a strange runtime error. I downloaded the windows binary and tried running it.
what installation method are you using?
I just downloaded the standalone windows binaries from Download Grafana | Grafana Labs
Try the zip one, copy your grafana db and ini, change pprt, fire up grafana-server from bin and see what happens
Yea I did that actually. I was using the zip one, unzipped, copied by data, and then tried running grafana-server. I got the same err with v10.3.0 and v10.3.1 but the one I was using v10.2.0 works fine.
