Dear all,
I unexpectedly started to observe error when saving alert rule. Please help to resolve.
- 11.2.9
- Save existing Alert rule after modifications
- Click Save rule
What happened?
- Change of configuraiton is not saved and error popup appears “Failed to save rule: failed to update rule group: failed to update rules: failed to create new rule versions: UNIQUE constraint failed: alert_rule_version.rule_guid, alert_rule_version.version”
- Successfull save after modifications
- Popup message as above and error in the log
logger=context userId=1 orgId=1 uname=admin t=2025-10-28T09:32:22.346657565Z level=error msg="failed to update rule group: failed to update rules: failed to create new rule versions: UNIQUE constraint failed: alert_rule_version.rule_guid, alert_rule_version.version"error=“failed to update rule group: failed to update rules: failed to create new rule versions: UNIQUE constraint failed: alert_rule_version.rule_guid, alert_rule_version.version” remote_addr=2001:808:0:1000:5534:7188:e4aa:9174 traceID=
This error started without any specific changes in the system. It’s not after upgarde or downgrade. Saving alert rules was working properly all the time.
Any help appreciated.
Regards,
Szymon
