Error after adding Azure monitor Data Source
    open-source version deployed in a kubernetes cluster with prometheus
    I want to add Azure monitor as a data resource
    I’ve created an app registration in Azure and assigned the Azure monitoring and Reader role to it
  • What happened?
    When I fill in my Azure credentials in Grafana it can find my Azure subscription and gives a green light. But when I open a dashboard this appears:
Error updating options: The client ‘’ with object id '’ does not have authorization to perform action ‘microsoft.insights/metricNamespaces/read’ over scope ‘/subscriptions//resourceGroups/;/providers/microsoft.insights’ or the scope is invalid. If access was recently granted, please refresh your credentials.
    That I would be able to see my Azure metrics in the dashboard
https://www.cognizantsoftvision.com/blog/how-to-integrate-azure-monitor-with-grafana/
In other articles I saw that you need to add the Reader role to Grafana in order to solve this, but this didn’t help for me.
My bad, I figured it out. I needed to assign the Reader role on the subscription level and not only on resource group level. Hopefully this will help someone else in the future.
Thanks, I was actually running into the same issue and you unstuck me.
I’ve been stuck for days on this. Thank you!
This also helped me.
Is this behaviour by design?
We have a subscription where grafana don’t have (read-)access to all resources.
It works fine with Logs and Azure Resource Graph, just not for metrics
