I am new to Grafana and trying to make my first steps with the tutorial. When setting up the tutorial I get an error message.
v. 12.0.2 -
Installation of tutorial environment -
Enter following command into the console:
git clone https://github.com/grafana/tutorial-environment.git
cd tutorial-environment
docker-compose up -d
- What happened?
The first two commands are executed without an error, the third caused:
Creating tutorial-environment_grafana_1 ... error
and further below:
ERROR: for grafana Cannot start service grafana: driver failed programming external connectivity on endpoint tutorial-environment_grafana_1 (9dbb60503d05c46cb7193c8f5a3f65a2855dc08e63e49a6d3cffcb7dc3353d1a): failed to bind port 0.0.0.0:3000/tcp: Error starting userland proxy: listen tcp4 0.0.0.0:3000: bind: address already in use
ERROR: Encountered errors while bringing up the project.
when I enter docker-compose ps I get
tutorial-environment_db_1 /db Up 0.0.0.0:8082->80/tcp,:::8082-
>80/tcp
tutorial-environment_grafana_1 /run.sh Exit 128
Creating tutorial-environment_grafana_1 ... done
and start the tutorials.
Could not find one. -
Grafana fundamentals | Grafana Labs
Any help would be appreciated.
Thank, Ralf
