I’ve been facing some issues with grafana and docker. I’m trying to get a grafana and influxdb up, for monitoring my MISP instance.
The project which I’m following is: https://github.com/MISP/misp-grafana
The InfluxDB docker is up and receiving logs via telegraf… seems to be working fine. But the Grafana Dashboards does not show up via https://ip:3000/login. From inside of the machine where MISP is running(the docker containers are also running on this machine) i can “CURL” the address and receive the HTML from Grafana’s login page.
Could someone help me? Have already tried lots of suggestions, but none of them work as expected.
I’ve already tried to disable Iptables and firewalld(since i’m using an CentOS7), and nothing helped.
My docker-compose file is:
services:
influxdb:
image: influxdb:latest
container_name: influxdb
volumes:
- influxdb-storage:/var/lib/influxdb2:rw
# - ./influxdb/ssl/influxdb-selfsigned.crt:/etc/ssl/influxdb-selfsigned.crt:rw
# - ./influxdb/ssl/influxdb-selfsigned.key:/etc/ssl/influxdb-selfsigned.key:rw
ports:
- "8086:8086"
environment:
- DOCKER_INFLUXDB_INIT_MODE=${DOCKER_INFLUXDB_INIT_MODE}
- DOCKER_INFLUXDB_INIT_USERNAME=${DOCKER_INFLUXDB_INIT_USERNAME}
- DOCKER_INFLUXDB_INIT_PASSWORD=${DOCKER_INFLUXDB_INIT_PASSWORD}
- DOCKER_INFLUXDB_INIT_ORG=${DOCKER_INFLUXDB_INIT_ORG}
- DOCKER_INFLUXDB_INIT_BUCKET=${DOCKER_INFLUXDB_INIT_BUCKET}
- DOCKER_INFLUXDB_INIT_ADMIN_TOKEN=${DOCKER_INFLUXDB_INIT_ADMIN_TOKEN}
# - INFLUXD_TLS_CERT=/etc/ssl/influxdb-selfsigned.crt
# - INFLUXD_TLS_KEY=/etc/ssl/influxdb-selfsigned.key
grafana:
image: grafana/grafana:latest
container_name: grafana
ports:
- "3000:3000"
volumes:
- grafana-storage:/var/lib/grafana
- ./grafana/provisioning:/etc/grafana/provisioning
depends_on:
- influxdb
environment:
- GF_SECURITY_ADMIN_USER=${DOCKER_GRAFANA_USERNAME}
- GF_SECURITY_ADMIN_PASSWORD=${DOCKER_GRAFANA_PASSWORD}
network_mode: host
volumes:
influxdb-storage:
grafana-storage:
The logs from Grafana container are:
GF_PATHS_CONFIG='/etc/grafana/grafana.ini' is not readable.
GF_PATHS_DATA='/var/lib/grafana' is not writable.
GF_PATHS_HOME='/usr/share/grafana' is not readable.
You may have issues with file permissions, more information here: http://docs.grafana.org/installation/docker/#migrate-to-v51-or-later
logger=settings t=2023-01-18T11:23:18.545281441Z level=info msg="Starting Grafana" version=9.3.2 commit=21c1d14e91 branch=HEAD compiled=2022-12-14T10:40:18Z
logger=settings t=2023-01-18T11:23:18.545574106Z level=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-01-18T11:23:18.545595127Z level=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-01-18T11:23:18.545601849Z level=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-01-18T11:23:18.545610343Z level=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-01-18T11:23:18.54561656Z level=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-01-18T11:23:18.545623137Z level=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-01-18T11:23:18.5456313Z level=info msg="Config overridden from command line" arg="default.log.mode=console"
logger=settings t=2023-01-18T11:23:18.545637996Z level=info msg="Config overridden from Environment variable" var="GF_PATHS_DATA=/var/lib/grafana"
logger=settings t=2023-01-18T11:23:18.545648448Z level=info msg="Config overridden from Environment variable" var="GF_PATHS_LOGS=/var/log/grafana"
logger=settings t=2023-01-18T11:23:18.545654176Z level=info msg="Config overridden from Environment variable" var="GF_PATHS_PLUGINS=/var/lib/grafana/plugins"
logger=settings t=2023-01-18T11:23:18.545663184Z level=info msg="Config overridden from Environment variable" var="GF_PATHS_PROVISIONING=/etc/grafana/provisioning"
logger=settings t=2023-01-18T11:23:18.545668879Z level=info msg="Config overridden from Environment variable" var="GF_SECURITY_ADMIN_USER=tsec"
logger=settings t=2023-01-18T11:23:18.545682275Z level=info msg="Config overridden from Environment variable" var="GF_SECURITY_ADMIN_PASSWORD=*********"
logger=settings t=2023-01-18T11:23:18.545689113Z level=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-01-18T11:23:18.545699682Z level=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-01-18T11:23:18.545705402Z level=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-01-18T11:23:18.545710714Z level=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-01-18T11:23:18.545732177Z level=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-01-18T11:23:18.5457395Z level=info msg="App mode production"
logger=sqlstore t=2023-01-18T11:23:18.545859098Z level=info msg="Connecting to DB" dbtype=sqlite3
logger=migrator t=2023-01-18T11:23:18.575806909Z level=info msg="Starting DB migrations"
logger=migrator t=2023-01-18T11:23:18.584646143Z level=info msg="migrations completed" performed=0 skipped=464 duration=1.036135ms
logger=plugin.loader t=2023-01-18T11:23:18.694560017Z level=info msg="Plugin registered" pluginID=input
logger=secrets t=2023-01-18T11:23:18.695056176Z level=info msg="Envelope encryption state" enabled=true currentprovider=secretKey.v1
logger=query_data t=2023-01-18T11:23:18.698004003Z level=info msg="Query Service initialization"
logger=live.push_http t=2023-01-18T11:23:18.709944098Z level=info msg="Live Push Gateway initialization"
logger=infra.usagestats.collector t=2023-01-18T11:23:19.076511711Z level=info msg="registering usage stat providers" usageStatsProvidersLen=2
logger=provisioning.plugins t=2023-01-18T11:23:19.133661231Z level=error msg="Failed to read plugin provisioning files from directory" path=/etc/grafana/provisioning/plugins error="open /etc/grafana/provisioning/plugins: no such file or directory"
logger=provisioning.notifiers t=2023-01-18T11:23:19.133823449Z level=error msg="Can't read alert notification provisioning files from directory" path=/etc/grafana/provisioning/notifiers error="open /etc/grafana/provisioning/notifiers: no such file or directory"
logger=provisioning.alerting t=2023-01-18T11:23:19.133926705Z level=error msg="can't read alerting provisioning files from directory" path=/etc/grafana/provisioning/alerting error="open /etc/grafana/provisioning/alerting: no such file or directory"
logger=provisioning.alerting t=2023-01-18T11:23:19.133951102Z level=info msg="starting to provision alerting"
logger=provisioning.alerting t=2023-01-18T11:23:19.133992848Z level=info msg="finished to provision alerting"
logger=ngalert.state.manager t=2023-01-18T11:23:19.134747843Z level=info msg="Warming state cache for startup"
logger=grafanaStorageLogger t=2023-01-18T11:23:19.140618617Z level=info msg="storage starting"
logger=http.server t=2023-01-18T11:23:19.140693638Z level=info msg="HTTP Server Listen" address=[::]:3000 protocol=http subUrl= socket=
logger=ngalert.state.manager t=2023-01-18T11:23:19.16651119Z level=info msg="State cache has been initialized" states=0 duration=31.757492ms
logger=ticker t=2023-01-18T11:23:19.166633607Z level=info msg=starting first_tick=2023-01-18T11:23:20Z
logger=ngalert.multiorg.alertmanager t=2023-01-18T11:23:19.166666209Z level=info msg="starting MultiOrg Alertmanager"
logger=context userId=0 orgId=0 uname= t=2023-01-18T11:23:27.6249068Z level=info msg="Request Completed" method=GET path=/ status=302 remote_addr=1.134.26.244 time_ms=0 duration=610.399µs size=29 referer= handler=/
logger=cleanup t=2023-01-18T11:33:19.14617771Z level=info msg="Completed cleanup jobs" duration=7.595219ms
The curl http://ip:3000/login command from inside the CentOS7 machine answer (just a part of it, since it’s big):
<!doctype html><html lang="en"><head><meta charset="utf-8"/><meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1"/><meta name="viewport" content="width=device-width"/><meta name="theme-color" content="#000"/><title>Grafana</title><base href="/"/><link rel="preload" href="public/fonts/roboto/RxZJdnzeo3R5zSexge8UUVtXRa8TVwTICgirnJhmVJw.woff2" as="font" crossorigin/><link rel="icon" type="image/png" href="public/img/fav32.png"/><link rel="apple-touch-icon" sizes="180x180" href="public/img/apple-touch-icon.png"/><link rel="mask-icon" href="public/img/grafana_mask_icon.svg" color="#F05A28"/><link rel="stylesheet" href="public/build/grafana.dark.960bbecc684cac29c4a2.css"/><script nonce="">performance.mark('frontend_boot_css_time_seconds');</script><meta name="apple-mobile-web-app-capable" content="yes"/><meta name="apple-mobile-web-app-status-bar-style" content="black"/><meta name="msapplication-TileColor" content="#2b5797"/><meta name="msapplication-config" content="public/img/browserconfig.xml"/></head><body class="theme-dark app-grafana"><style>.preloader {
height: 100%;
flex-direction: column;
display: flex;
justify-content: center;
align-items: center;
The telnet ip 3000 command from another machine gives me and error.
The `netstat -naput | grep LISTEN" on the CentOS7 machine:
tcp6 0 0 :::8086 :::* LISTEN 30124/docker-proxy-
tcp6 0 0 :::3000 :::* LISTEN 30241/grafana-serve
I’ve already tried to change de 3000 port to another one (avoiding firewall blocks) but it did not work.
Help me please…
