Hi Team,
I have “x509_cert” data from Telegraf to InfluxDB. Below is my query which I am using in dashboard.
from(bucket: "monitoring_metrics")
|> filter(fn: (r) => r["_measurement"] == "x509_cert")
|> filter(fn: (r) => r["_field"] == "enddate" or r["_field"] == "startdate" or r["_field"] == "expiry" or r["_field"] == "age")
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
|> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value")
|> sort(columns: ["_time"], desc: true)
|> last(column: "_time")
|> group()
The fields from above query “startdate”, “enddate”, “expiry” are all UnixTimestamp. I would like to show them in the human readable date format.
Can someone please provide an insight on how to handle this ?
Regards,
Pradeep
Just set correct unit for each column, use custom override for each column, e. g. Time / duration (s) for age, etc.
Hello @jangaraj ,
Its not working.
Looks like there are some posts with similar issue
Thank you.
dumpalap:
Its not working
great, this terrible problem description: no details what you configured/tried, what’s exact input/result,…
It’s just not working.
These docus might be of help
Have you tried playing around with different units? Seems like your timestamp is in different unit than seconds.
Hello @jangaraj , appologize for earlier response… some have it got accidentally submitted without my complete message and attachment. When I apply the unit type, some have its displaying them 1971 as year.
I was referring some other posts and tried below… which looks be working.
Thank you.
IMHO you can multiply by 1k on the InfluxDB level directly - that should be faster.
good thought… @jangaraj . I will give a try .
thank you.
