Enter duration/end time manually in state timeline
Is it possible to enter a duration or end time in the state timeline. This is possible in the Gantt chart (marcusolsson-gantt-panel).
Because this plugin is not maintained any more, so I want to switch to the state timeline (or another plugin)
If I use the same kind of data, the following state timeline is shown:
The problem is that there is no end time for these intervals
I have a similar problem with duration. Have you found a solution for your task?
We have the same problem, found no solution so far
