Hi, i am testing the free Hosted Grafana Instance and i would like active the “Enabling anonymous login”, i found that i should edit “grafana.ini”, but it is not enabled in Hosted Instance.
Is there a option to enable “anonymous login” or it is only available for Grafana Cloud subscriptors.
I mean to a instance. I have created my own Instance on Grafana server, that is what i mean with “free Hosted Grafana”. This options is available when you are hosting self Grafana (e.g. localhost:3000). In the case of “hosted Grafana”, there is no option “Invite (green button)”. Instead of these says:
Users are managed via grafana.com. The table below shows users who have logged in at least once. To remove a user you also need to remove them from your grafana.com org.
I can not find an option into grafana in order to create new user, at least “no” using free version.
I would like know it is only available using “Grafana Cloud”. If you know, please let me know.
I host my own instance in my server and here I can assure you that you can create all the users that you want. Even create an anonymous user without password, but I do not tried yet.
The way to do that is: (but, as you can see, you have to access file system)
sudo nano /etc/grafana/grafana.ini
disable_login_form = true
# enable anonymous access
enabled = true
# specify role for unauthenticated users
org_role = VIEWER
