Enable Public Dashboards in Grafana in Home Assistant
Hello all,
I’m new to Grafana
I’m using Grafana with influxDB as Home Assistant add-ons and want to display some dashboards directly on a screen using digital signage software. I read about public dashboards and wanted to use them but it does not appear for me as an option(like sharing with links or snapshots) and i didn’t know how to enable them.
thanks a lot
fsl
Grafana dashboards are designed to be viewed in a web browser.
Does this “digital signage software” act as a browser, or can it make use of a
browser to render what is to be displayed?
Antony.
Yes, i use Xibo and it supports webpage layouts, works perfectly with snapshots but i need to display live Dashboard.
A brief look at https://xibosignage.com/ suggests to me that this thing is
designed more for displaying a sequence of static images rather than acting as
a standard refreshable browser.
I think this is not the right choice for viewing Grafana.
Antony.
Thank you Antony!
is there a way to share dashboards live with updated data?
