Enable Missing HttpOnly Flag From Cookie in Grafana
    9.4.3
Fixing Vulnerability_Risk: Missing HttpOnly Flag From Cookie
Looking for the config change in the Grafana to fix the Missing HttpOnly Flag From Cookie
  • What happened?
    Getting Vulnerability_Risk from Grafana after security assessment: Missing HttpOnly Flag From Cookie
Received below recommendation in the grafana but not sure where to make this change.
Add the HttpOnly to all cookiesFor each cookie generated by your web-site, add the “HttpOnly” flag to the cookie. For example: Set-Cookie: =[; =] [; expires=][; domain=<domain_name>] [; path=<some_path>][; secure][; HttpOnly]
NA
    No
Currently in grafana configuration link given above, there is no option for setting httponly on all cookies. Would this be consider as a security feature?
