Grafana v10.4.2 -
I have a nested field in elasticsearch called Components. When I visualize it in a table in grafana the column components looks like this:
components:
"bitrate": 0,
"children": [
{ "bitrate": 361427, "codec": "H.264", "content_type": "Video", "framerate": "50.00","resolution": "640x360p" },
{ "content_type": "Audio", "index": 1, "level": -15.7, "level_3sec": -16.9,
"loudness": {
"daily": { "integrated": -16.8, "lra": 8.9 },
"per_channel": [
{ "ch": 1, "level": -15.7, "level_3sec": -16.9, "peak": -6.7 },
{ "ch": 2, "level": -15.7, "level_3sec": -16.9, "peak": -6.7 }
I want to be able to create a table that has… for specific values in the nest. Or even a visual so i can access the data inside the nested fields
For example
components.children where content_type = “Video”
|Bitrate | codec | content_type | framerate|
|361427 | H.264 | Video | 50.0|
How do I access the nested data
