Hello everyone.
Help me, please!
In Elasticsearch, every document has a field object with nested fields. In Grafana, they are displayed like this:
"request" : {
"headers" : {
"accept" : "text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8",
"cache-control" : "max-age=0",
"connection" : "keep-alive",
"upgrade-insecure-requests" : "1",
"accept-encoding" : "gzip, deflate",
"user-agent" : "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:88.0) Gecko/20100101 Firefox/88.0",
"accept-language" : "en-US,en;q=0.5"
As you can see, Grafana expands nested fields to final keys:
But I need to display
request.headers field content in the one column as JSON.
Is it possible?
I also want to do something similar to this, but my object looks more like this:
"shard_counts" : [
"name" : "es-live-6",
"shards" : 117
"name" : "es-live-3",
"shards" : 116
"name" : "es-live-2",
"shards" : 117
"name" : "es-live-1",
"shards" : 117
"name" : "es-live-8",
"shards" : 117
At the moment shard_counts in a table just shows as: [object Object],[object Object],[object Object],[object Object],[object Object]
How can we turn nested objects into a table of data?
ashil
July 1, 2021, 6:21am
3
Have you figured it out how to work with the list of object?
Unfortunately, I haven’t found a pretty solution yet.
Now I’m converting an object into text JSON on Logstash into a additional field, just for display.
This is bad because an additional field is being created.
I couldn’t display it in a table, but when I changed the display type to a Stat rather than a table then it worked.
