Hi, we have a document like follows:
"_index": "1",
"_type": "_doc",
"_id": "2018-11-12 7:00:00 - 2018-11-12 7:30:00",
"_score": 1,
"_source": {
"start": "2018-11-12 7:00:00"
"obj1": [
"key1": "value",
"key2": "value",
"key3": "value",
"key1": "value",
"key2": "value",
"key3": "value",
where type of obj1 is nested
In Dashboard Metrics tab, i am using metric Average and value obj1.key1 and grouping by the time field start but the graph is not getting plotted as all the values obtained in the response are null even though they arent null.
Does Grafana support querying nested structures ? if not, will it do in the future ?
But i have created a patch over the one created by arcolife. i can share it with you if you want
