ElasticSearch to geomap
Greetings,
  • v8.4.5 Windows 10
    map lon lat from elastic search
    in grafana pointing to our elastic search
  • What happened?
    I am not able to plot the lon lat
    I expected to be able to see and plot my long/lat data
    None
    Cant find one for the specific thing that I am trying to do for the last 3 days
Coords specifies that your query holds coordinate data. You will get prompted to select numeric data fields for latitude and longitude from your database query.
Your fields are not numeric, but strings, so their format is quite weird to be processed by geomap.
Quick demo with SQL datasource to prove that geomap is working with correct numeric data correctly:
Thanks very much @jangaraj . So found the numeric values in another field set
location.lat
41.866
location.lon
-89.277
But for some reason they do not show up in grafana’s elastic search query. Something else for me to tackle, but you have answered my question. Thanks much!
