Visualize GPS coordinates in Map
Good morning,
I’m quite new in Grafana. I’m using Grafana (v8.4.6) together with an influxdb, which is feeded from Openhab3. I want to visualize the following GPS coordinates (which are yet still all the same) in a map:
I was already playing around a bit with the Geomap visualization, but unfortunately I do not manage. This is how I set the data layer section:
Maybe one of you could guide me into the the right direction - mayn thanks!
Matthias
Have you checked out this sample dashboard?
let me ask around and see if we have any more samples…
https://play.grafana.org/d/f6aHs_0nz/new-dashboard-geomap?orgId=1
Hi @matthias007 , just stumbled over your question as I tried to solve the same problem. Finally I found the following solution.
Grafana needs the fields “lat” and “lon” in the result to use them as geodata. With influxdb version 2 and flux queries, the solution is then to add a mapping to the flux query. This works for me:
import "strings"
from(bucket: "openhab/autogen")
  |> filter(fn: (r) => r["_measurement"] == "Flash_Location")
  |> map(fn: (r) => ({r with lat: float(v: strings.split(v: r._value, t:",")[0]) , lon: float(v: strings.split(v: r._value, t:",")[1]) }))
  |> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: true)
  |> fill(usePrevious: true)
Check out whether it works for you also.
Wondering why you are doing the mapping and aggregation? Does the lon, lat data have something that needs to be cleaned up and converted to float?
