Grafana version - v9.3.8
OpenSearch version - 2.3.0
Adding new datasource -
From UI -
What happened?
“Elasticsearch error: 404 page not found” when save/test new datasource
No errors
Error in UI:
In Grafana pod logs:
t=2024-02-16T16:43:17+0000 lvl=info msg=“Request Completed” logger=context userId=1 orgId=1 uname=admin method=GET path=/api/datasources/proxy/1/xy-xyz-abc-abcdef-*/_mapping status=404 remote_addr=10.244.1.0 time_ms=106 size=19 referer=https://abc.xyz.com/datasources/edit/1/
- Did you follow any online instructions? If so, what is the URL?
